S9 plus Bluetooth keep disconnecting within 30 seconds if paired with any speake
(Topic created on: 04-28-2018 12:27 PM)
Shivu46
Hi Team
I have experienced another issue in which we can't listen to songs with Bluetooth speakers I tried with all speakers and found that if we connect it will be connected for just 30 seconds then its will be disconnected. I have seen so many people facing same issue. It should be fixed as it doesn't suits on high end phones. I switched from nexus google to samsung and thinking whether I made a mistake.
4 Comments
thelegend
ya u made the greatest mistake of your life buying a galaxy
GalaxyTeam
Indian S9/S9+ Telegram Support Group, Join Us (300+ Members)
https://t.me/joinchat/DvvVrkv68Wr7Q3P0BKHnVAeb729d62-a6e7-4a9c-9710-b1fc2321ca4a.jpg
admin_
Thank you for sharing your concern. The relevant department will serve you better, if you can provide logs/video within 15 minutes of issue occurrence by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports). Be sure to hit ♡ when you find an answer that works for you.
For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Not applicable
Even I am facing same issue with my S9 Plus handset. My bluetooth earphones, Gear S2 keeps disconnecting frequently.
