S8 sensor problem....
(Topic created on: 07-23-2018 12:48 PM)
sabirul21
why s8 auto brightness,calling time air screen on-off not working?how to solve it?
8 Comments
umi
factory reset
sabirul21
have another way???
umi
open your device in safe mode if everything works fine then restart your device and go to settings then reset app reference if anything doesn't work good in safe mode then factory reset your device
luckly
hi
sabirul21
hi
admin_
We do apologize for the inconvenience caused. We would like to inform you kindly follow the steps below to resolve your concern:-
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Please run your device in safe mode.
- Please do reset your device on factory mode after taking the data backup Via Smart switch and remove the Google account.
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
Striker247
Did you fix this?
sabirul21
No
