S8 problem.
(Topic created on: 09-24-2018 02:52 PM)
ArifS8
Beginner Level 4
Im facing some problems with my S8.
I think when im playing games like Asphalt 9 that time my sensors is not working well.
How can i check my all sensors activity.
7 Comments
maher
mine working fine
R3ady
Press *#0*# to test all your sensors
ArifS8
Beginner Level 4
Look at this. Here im facing some fail in Magnetic and gyroscope sensors.
Mohamedsifras
Jackie1982
Ramadevara Betta Ramnagar one of the beautiful place near Bangalore.....Sholay movie shooting spot after 43 years
https://youtu.be/8Z-fwHrjfmw
admin_
Thank you for reaching out to the Samsung community! We would like to inform that you can check for the device sensor from Samsung members app diagnostics section. Open Samsung members app>>Diagnostics>>Test hardware. If you found any issue kindly follow the below steps:
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Run your device in safe mode.
- Reset your device on factory mode after taking the data backup Via Smart switch and remove the Google account.
- If still issue persists, we would suggest you to visit nearby Samsung Service Center in order to get your device physically inspected by the service engineer. Please find service centre details in the link provided -http://www.samsung.com/in/support/servicelocation
Be sure to hit ♡ when you find an answer that works for you. For further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
