S7 Usb tethering problem
(Topic created on: 03-15-2018 04:46 PM)
Yoganandan
I'm using S7. I was using usb tethering without any issues. but it was not connecting now with my laptop but other mobile can connect using the se usb tethering. what would be the problem and how to resolve?
8 Comments
k7
install Samsung usb driver and use original usb cable
Yoganandan
To my laptop or mobile? can you give me the driver link?
k7
install driver to your laptop
Bagga
USB driver update
Bagga
mere saath bhi bhai aisa hi hat
Bagga
s7 edge use ksrde bro ma v
admin_
Thanks for being a part of Samsung community. We would like to inform you kindly follow the steps below to resolve your concern:-
- Navigate to apps >> Settings >> Apps >> Tap on three dots >> Reset app preferences.
- Kindly visit the link http://www.samsung.com/in/support/usefulsoftware/KIES/ and download Samsung kies 3.2. It includes all the Samsung device software required to connect with PC.
- Please run your device in safe mode.
- Please do reset your device on factory mode after taking the data backup Via Smart switch.
Be sure to hit ♡ when you find an answer that works for you. For Further assistance, you can get in touch with us via Live Chat option by following- http://livechat.support.samsung.com/Customer_new/IN. You can also connect us via Samsung Members web community by following mentioned url-https://community.samsungmembers.com/en_IN#/
usb
USB cable not connecting
