S7 Oreo Battery Charging
(Topic created on: 06-12-2018 12:44 PM)
Ssevenuser
Guys, After updating to oreo. My Samsung S7 is taking so much time to charge to 100%. It is taking approx 3 hr which is 2.15 min on nougut. Are you facing the same problem?
11 Comments
skshedbal
Nope
mine is taking just 1hr 12 mins
check if fast charging is ticked
Toufik
not sure bt after oreo battery goes fast down
lsn
Enable power saving mode. It is pathetic in android N but works good in Oreo
nbs
battery drains so fast aftr updating to oreo
no problem .Phone is full charged in approx 1hr 15min.
Rahamatullah
no my s7 edge take 1hr 15 min
bhajansharma
mine 1hr 30 min.
zayd
No
Vijaypoul
yes i m also facing the problem
fast charging not working
