Abilash
02-15-2017 09:52 AM in
Hi it's been a few weeks since I am facing this issue. My phone loses Internet connectivity even though it's connected to the WiFi and the WiFi has internet.
I have to switch off my WiFi and reconnect it to get back the Internet. It's extremely annoying.
I Googled and I found a few articles indicating it was related to power saving and Bluetooth but to no avail. It didn't work.
This has happened on WiFi networks, not just on one. I have tried forgetting the network and reconnecting again. No use.
I really don't want to do a factory reset. It takes a lot of time to restore.
Any help would be appreciated
3 Comments
VinayRai
02-15-2017 10:12 AM in
Try ur luck in Safe Mode. See if it works otherwise no other option.
raju15
02-15-2017 10:41 AM in
check the settings of wifi! check 'wifi on in sleep' have tickmark or not?
Samsung_India_
02-16-2017 02:46 PM in
Thanks for being with Samsung and for sharing your concern. Let me recommend some steps to further isolate and determine what you are experiencing. Please be aware that device speeds may vary based on multiple outside factors. It appears that there may be a third party app or other program that may be leading to what you are experiencing. Placing your device in safe mode disables all third party apps upon startup, to help determine if the use of a third party app is interfering with your device .restart your phone in safe mode. While your phone is powered off, press the power button to turn on the phone, once you see the Samsung logo appear press the volume down key and hold it until you have completely booted up. Also, the relevant department may serve you better/speedily, if you can provide logs/video by registering this feedback in Error Section (Samsung Members App -> Feedback -> Questions/Errors -> Create -> Error reports).
