mohit712
01-19-2017 10:12 PM in
Does anyone have the problem of fingerprint not being recognised properly? If I place my finger horizontaly it recognises it, but if it's vertical it doesn't & I have to try it again. Help if there's a fix, it's really annoying.
P.S.- I have registered 4 fingertips.
6 Comments
MrAwesome
01-19-2017 10:14 PM in
just register your finger in all directions.
and you can do that in 1 fingerprint only.
try it out and let me know if it helps :)
Xahoor26
01-19-2017 10:31 PM in
ya nice reply this will definitely work
mohit712
01-19-2017 11:07 PM in
It seems to work fine now. Thanks! 😄
vickyyyyy
01-19-2017 10:23 PM in
This won't happen if you set it up properly.
srikanthrao
01-19-2017 10:27 PM in
Hi first delete the all fingerprints and set again it'll work's fine.
Samsung_India_
01-20-2017 01:24 PM in
Thanks for being with Samsung and for sharing your concern. We are delighted to see that everyone is trying to help another. We would suggest you that register your fingerprints in all directions.
