S6 Edge Download Problem
(Topic created on: 05-11-2017 09:58 AM)
MohamedRezeem
Have anyone facing the issue.If I'm downloading anything in my s6e, example movies in UC browser or uTorrent. When Using there is no probs,but When I lock the phone for15-20 minutes it automatically stops in UTorrent and In uc browsers it shows failed .And again when I unlock the phone only it starts.
I usually do When I go for sleeping I will start the downloading in UTorrent and by morning it will be finished now I can't do anything.
From nougat only the problem started ???
My wifi is always on.
26 Comments
Not applicable
No I don't have this issue
Do you use greenify app ?
MohamedRezeem
nooo broo I don't use any 3rd party apps for battery.
Have you use UTorrent without any probs???
when I lock only the probs will start
Not applicable
I do not use utorrent but I download from UC always and never had any issue during lock, only issue is when closing all recent apps then download paused, although on MM download continued even after closing all apps
shubh
disable power saving mode and fingerprint during background downloading. it might help you
MohamedRezeem
i don't use powersaving
fingerprint????
S10PlusIndia
Its happening in whatsapp also. Ifter lock the phone no any msg received but when I open whats app then all msg received togather... But there is a solution. By default new update it monitors all app which are running in background and put them sleep. you can unrestricted then in battery setting.
MohamedRezeem
broo I have unmonitored these two apps and when I unlock the phone it automatically pauses😭😭
shubh
yes i noticed it too but disabling fingerprint it worked for me
MohamedRezeem
broo I didn't get
i have unmonitored
are you telling about these???
plzz help yaar
broo my device is running in nougat
