S25 ultra camera rattling noise and screen flickers
(Topic created on: 04-14-2025 03:15 PM)
nsanket
I am facing a weird issue when I switch to Ultra Wide(0.6X) lens. It struggles to focus and creates a weird stuttering sound. Anybody else facing this issue?
16 Comments
goodthings
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
At Samsung, we always aim to provide impeccable services to our customers, and we highly regret that you feel this way.
Please follow these easy troubleshooting steps which may help in resolving this issue:
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
Ro0hit
facing same issue 😪
as_hok
Beginner Level 3
Facing same issue camera rattling sound and blur pics in s 25 ultra
nsanket
Its a hardware bug i have guven the device for camera replacement in a Samsung service center
Ro0hit
same here in s25 ultra
nsanket
I ahve given my device for camera replacement. Lets see
Ro0hit
ok please update after that....
