S25 plus battery life issue
(Topic created on: 02-18-2025 04:29 PM)
ChrisMk
Its been 1 week since i switched to the s25 plus.unfortunatly i feel like my battery life aint this good.
For using it for online like 3 hrs my battery drops by a lot.even the estimated battery usage is very low.when i check on my old phone the A33 5g,it had 1 day 9hrs on it.
Do you think i should use warranty ?
Or should i wait ?
19 Comments
The device will adjust once it knows your usage patterns.
Just try and avoid charging it to 100% unnecessarily.
Try using adaptive or maximum battery protection, this will avoid "frying" your 🔋.
ChrisMk
From day one i used adaptive protection
ChrisMk
Base s24 has better battery than mine
Munatsi399
Use your warranty it maybe a faulty battery, considering that your device is supposed to be economic on battery usage....
just my thought 🤷 ♂️
ChrisMk
Am going to wait a bit,if things continue like this am going to use my warranty
Munatsi399
Okay.... cool. How is your screen brightness setting, is it adaptive?
ChrisMk
Adaptive plus i use extra dim on max
Munatsi399
Okay cool
Smekahle
You must be a heavy user.
