24 ultra battery ussage
(Topic created on: 2 weeks ago)
jasonpaulse665
Hi.
I have an s24 ultra. I'm using all original charging equipment, 25w super fast charger. I upgraded because I enjoy long battery life. However my battery consumption is super rapid.
I read that you shouldn't use smart switch, we'll I did. Is this the issue?? Please help.
8 Comments
Look at that. 2hrs to full. Using a super fast charger. 1716991836928_1716991836917_0.jpg
Dali1234
Good day. Have you checked your charging settings if fast charging is enabled? This is too long for fast charging. Something is wrong here.
I updated. Restated and it's now fixed.
Dali1234
TeeA
How long have you had the phone?
A little less than a month
TeeA
Alright I'm unable to give you the knowledge of what happens during the first two weeks of having it.
What I will say is that it could be the 6.1 update since a lot of users have reported issues with it with battery charging/drain being the biggest one, even if your phone started with it. Smart switch may or may not be the issue, you can also try clearing the system cache, disable the fast charging and then re-enable it or back up everything and perform a factory reset.
I also had slower charging after the March update on my S23U but the April update fixed it so I hope in your case that the next monthly updates should fix it 🙃
