S25 plus battery draining quickly
(Topic created on: 04-18-2025 12:46 PM)
kpu007
Is there any known issues with the S25+ model with battery backup. Not even lasting a day, even after putting unused apps to sleep and adaptive power saving enabled.
5 Comments
Aafu911
Don't worry the only thing that will last forever on your phone will be the existing software as they won't upgrade you next year 😂
Samsung_specialist
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
   - Step 1: Go to Settings > Software update.
   - Step 2: Tap on Download and install.
   - Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
   - Open Settings > Battery and device care > Optimize now.
   - Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5.  Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
If you have attempted these steps without success, we kindly request you to visit the nearest service center for a physical inspection of your device. You can locate your nearest service center using the following link: (https://www.samsung.com/ae/support/service-center/)
kpu007
Please note these steps and all are tried out. Yet the battery on this model doesn't last even a day. Do S25+ has any such known issues. Please update
kpu007
Please note that it has gone worse after recent software update. Is there any resolution to this issue
geo_777
Not only S25 plus, it seems entire S25 family have battery issues, despite applying all tips and even sacrificing 120hz refresh rate and keep phone in power save mode all the time , still battery draining so fast even in standby times
