06-12-2025 12:00 AM in
Galaxy S- Mark as New
06-12-2025 12:41 AM in
06-12-2025 04:21 AM in
06-12-2025 12:57 AM in
06-12-2025 03:30 AM in
06-12-2025 03:39 AM in
06-12-2025 04:10 AM in
06-12-2025 01:44 AM in
a month ago in
Galaxy STo address the battery drain concern, we recommend performing additional troubleshooting steps to identify the root cause of the issue. These steps may include:
1.Force restart by pressing “volume down key + power” button until the device reboot. After reboot below action.
2. Path: Settings – Apps - One UI Home – Storage - Clear data.
Then check :
1. Update Software: Ensure that your device's software and related apps are updated to the latest version. To update your mobile device's software, follow these steps:
- Step 1: Go to Settings > Software update.
- Step 2: Tap on Download and install.
- Step 3: Follow the on-screen instructions.
2. Setup Phase: Your new phone’s battery may initially drain faster as you set up applications and features. This is part of the setup phase, and background operations are optimized during this time. Allow a few days for all background operations and syncing to complete.
3. 5G Service Impact: While connected to a 5G network, your phone may consume more battery than usual due to the high-speed processing of large-capacity data. Consider optimizing overall usage and adjusting background usage limits.
4. Optimization Steps:
- Open Settings > Battery and device care > Optimize now.
- Adjust Background usage limits: Settings > Battery and device care > Battery > Background usage limits.
5. Use adaptive battery: Settings > Battery and device care > More battery settings > Adaptive battery.
If you have attempted these steps without success, we kindly request you to visit the nearest service center for a physical inspection of your device. You can locate your nearest service center using the following link: (https://www.samsung.com/ae/support/service-center/)
