S25 have some resolution issues and Slack application doesn't work for call
(Topic created on: 03-05-2025 07:35 PM)
ams25
Widely used slack application has performance issues in S25 device. User is not able to start huddle/ call. Screen misbeaves while staring call and then it crashes.
Observed some resolution issues while using Gpay app (on final enter password screen).
Also,if we go to settings, profile image displayed next to samsung account doesn't fit properly in the section and it's blurred.
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
