05-18-2025 12:00 AM (Last edited 05-18-2025 12:01 AM ) in
Galaxy S- « Previous
- 1
- 2
- Next »
07-05-2025 11:52 PM (Last edited 07-05-2025 11:53 PM ) in
Galaxy S- Mark as New
05-18-2025 10:16 AM in
05-19-2025 02:47 PM in
Galaxy SDear Samsung Member,
● Reset the camera settings: Tap on Camera>Settings>Reset settings>Reset.
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.
07-05-2025 11:43 PM in
07-05-2025 11:54 PM in
07-13-2025 07:35 AM in
07-13-2025 09:19 AM in
- 1
- 2
- Next »
