Thursday in
Friday in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
β’ Kindly create data backup of your device via SMART switch mobile application or http://www.samsung.com/in/support/smartswitch pc suite.
β’ Remember google password before resetting the device because it is required during initial setup.
β’ If you do not remember it, then reset, (Forgot password) your google account.
β’ For this:
β’ Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next
