S24fe ui problem
(Topic created on: 2 weeks ago)
Jeeŧ47
  1. Why my YouTube not showing description, channel details, and the Like/Dislike options.
10 Comments
Jayu1806
Clear cache data of youtube application and reopen it should be fixed or update the app from goole play store
Jeeŧ47
I clear the cache already and update my yt
And also uninstall the app and install it after that the full description, channel details, and the Like/Dislike options are showed and after some time it disappeared...
Jayu1806
It's not ui problem bro
It's app causing the error
Because sometimes that same issue i had faced several time in my 24 plus by the time it will be fixed automatically
Jeeŧ47
Hope so
VA4
It's YouTube bug.
Jeeŧ47
Any solution or it resolves automatically
VA4
No solution as of now. It should resolve automatically.
Jeeŧ47
Okay 👍
Jayu1806
Google is having a issue with their some apps so it should fix by it self there is no option to fix that problem
