S24 ultra " lift to wake" problem
(Topic created on: 03-04-2024 10:11 AM)
rajibulroney
The " lift to wake" option is turned on, but it doesn't work. Is there another setting that to be set?
10 Comments
Abhi_S24ultra
U r seeing only this as a problem ? Also check for S24 display quality issue & join WhatsApp group if u able to identify this on ur device:
https://r2.community.samsung.com/t5/Galaxy-S/S24-ultra-display-issue-while-watching-video/td-p/15661...
Ravihere
Just rest or restart........
rajibulroney
I did, but it's not happening. It worked when I first bought it. But now it doesn't.
Ravihere
It's upto date (software update)......?
Ravihere
If it's upto date than you should complent to samsung service :-
samsung.comhttps://www.samsung.com › contactSamsung India - Customer Care
https://www.google.com/url?q=https://www.samsung.com/in/support/contact/&sa=U&sqi=2&ved=2ahUKEwiHybe...
rajibulroney
Yes, up to date
Ravihere
Than you have to complent......
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click 3dots in my reply section and click on accept solution. Thanks.
cs_member8
Dear Samsung Member,
As per your query, we request you to share the log file. This will help us to further investigate and resolve this issue.
To attach the log file: Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
