S24 ultra massive issues and solved
(Topic created on: 05-29-2024 04:11 PM)
UchihaR
Last time i installed May security update on 16th May. It gave me a massive issue abt s24 ultra's battery draining problem. I mentioned it in my previous post. Tried everything I could, but the problem remained .Then I did the factory reset/ hard reset. Now the issue is gone. But the question is why a flagship phone like s24 ultra had this kind of issue or issues? Last time when I faced this issue in my s24 ultra, I almost decided to switch to another brands phone. In May security update had a lots of malware. So this time I m not going to update June security update so soon. I will observe. If everything is ok, only then I will update. Those who didn't update May security patch yet, don't install this update. Wait for June security update. Observe , ask your questions here in Samsung member. Read the replays, and if anyone already updated but still facing battery draining issue, do factory reset your s24 ultra. I didn't gave up because this phone cost me RS 1,85,500. That's a lots of money for many other people.
Another update u should do is Google play system update. For that go to About phone- Software information - Google play system update. Tap on Google play system update. If your s24 ultra is not updated, download the update.
Security patch update and Google play system update makes the phone more smooth.
That's all. If I miss something, pls share here. Share your experiences, problems or thoughts abt s24 ultra.
Thnx.
21 Comments
RAMULTRA24
Hi,
Good Information my dear friend..
All S24 Ultra Users once check below Issue mobile once.....
Even I am unable to use samsung S24 Ultra even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become DIM after that it will become Normal only after you go it Indoor..
Unable to Use it even 10 Minutes in Sunlight Displayyyy..
Even we checked in My friend's S24 Ultra, Similar Issue in that Mobile also....
This Issue is Not there in S23 Ultra...
The S24 Ultra Display is very bad & Worst Display even when you compared to S23 Ultra also...
it's BIG ISSUE in a Samsung S24 ULTRA Flagship Mobile But Samsung was Unable was not taking this issue very Seriously and Fixing it !!!!
Even 10 thousand mobile we can use as much as time in Sunlight and it's Display is Super in Sunlight...
But Purchasing S24 Ultra Flagship Mobile of Samsung with Lakhs of Rupees But Unable to Use for even 5 minutes in Sunlight...
This is Very very BIG ISSUE in the Samsung Flagship Mobile S24 Ultra.
So Surely it's Samsung Responsibility to fix this Issue
or
Else Do Recall All S24 Ultra mobiles and change Displays
or
Refund to all effected S24 Ultra users
UchihaR
Thank u.
I remember this issue. In my last post and in my other post, u mentioned this issue.
So, your direct under sunlight s24 ultra display issue is not solved yet. That time, I replayed u ,my s24 ultra is not facing this direct under sunlight display issue. Till now, I m not facing this issue. Actually, I don't have any idea why your s24 ultra is having this issue.
Is your adaptive color tone on or off?
Screen mode vivid or natural?
Did u do anything in easy mode?
Did u do anything in the screen saver option?
If u share the above info here, maybe I will be able to understand. Maybe, I'm not sure. So pls share.
RAMULTRA24
It's Not Resolved,
Many S24 Ultra Users facing this issue....
Adaptive Color tone is ON,
Natural,
No Screensaver,
UchihaR
Turn off adaptive color mode.
UchihaR
If u don't use any apps often ,put them in deep sleep. Once or twice in a month remove them from deep sleep. Look for the updates. Update them, then again in deep sleep.
Turn of auto update option for galaxy store. Do it manually. Even do update the major ONE UI updates manually. Stop all the auto updates.
If these things don't work, do factory reset/ hard reset your phone and set up very carefully. Use black color wallpapers. Never use colorful keyboard. Though those options are made for use, but they are not good for the phone.
UchihaR
Adaptive brightness ,use it.
Turn off Adaptive color tone.
Screen mode, keep it in natural mode.
Screen resolution, keep it in FHD+ .
do not use easy " easy mode".
After doing all these when u will face the same issue, maximize the brightness.
Do it over and over when u feel it's necessary.
I think something went wrong when u factory reset the phone. That time device care learn how u use your phone, when u go under sunlight, when u watch videos, playing games, use S pen, what kind of wallpaper u use.Every single thing related to s24 ultra.
Every time I do reset/ factory reset, I take atleast above 5 hours. Every single details always matters.
RAMULTRA24
Whether adaptive Brightness is Automatic or Manually, we need to us 100% Brightness in Sunlight to make good visible in Sunlight
After 3 Minutes are So The Screen is getting Over heated and Automatically the Screen is getting DIM...
I always use Natural, FHD+, onlyyy
Even 10 thousand mobile will be Good Visible for very Good time not like S24 Ultra...
Even S23 Ultra Display is Very Good Visible for Any loner times, it's not getting heated or not getting DIM
UchihaR
Understood. But don't give up. The solution is here. U just have to look deeply.
Understand your phone. It will also understand u.
Ha ha s24 is just the shitest phone ever. And. Im a isuer from s1
