S24 ultra lagging problem issue in oneui8
(Topic created on: 10-08-2025 11:26 AM)
Shivamwalia9
S24 ultra lagging problem issue in oneui 8 i didn't expect this from samsung ultra series lagging issue after purchasing costly flagship device Samsung please fix this issue. Some time it lags on normal apps like Amazon, flipkart & after restart also. Very very disappointed 😔 with Samsung.
3 Comments
Dev_1193
Same problem in my S25 Ultra, feels laggy & call recording notification on lock screen glitches.
cs_member10
Dear Samsung Member,
● Check space availability: Settings > Battery and device Care > Storage.
● Check RAM in your device: Settings > Battery and device Care > Memory.
● Check app cache: Settings > Device care > Storage > CLEAN NOW.
● Clear cache memory of a particular application: Settings > Apps > pick the app > Storage > Clear Cache.
● Close Background Apps.
● Remove third-party applications.
● Remove memory card: Apps > Settings > Device maintenance > Storage > More option > Storage settings > SD card > Unmount.
● Remove third-party accessories.
● Kindly disable Power saving mode( if enable).
● You can reset your device by following the steps:
3. If you do not remember the password then advise to reset (Forgot password) your Google account.
Path: Settings> General Management.>Reset>Temporary cloud backup or External storage backup>After backup tap on Factory data reset to reset your device to its factory default settings. This will erase all data, including files and downloaded apps.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.)
Shivamwalia9
My device is brand new
