07-08-2024 04:30 PM (Last edited 07-08-2024 04:31 PM ) in
Galaxy SAfter JUNE 2024 Update also the below ISSUE was not fixed..
So Dissappointed 👎 👎 👎
SAMSUNG Urgently need to fix below Issue....
All S24 Ultra Users once check below Issue mobile once.....
Even I am unable to use samsung S24 Ultra even 10 minutes in Sunlight...
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become DIM after that it will become Normal only after you go it Indoor..
Unable to Use it even 10 Minutes in Sunlight Displayyyy..
Even we checked in My friend's S24 Ultra, Similar Issue in that Mobile also....
This Issue is Not there in S23 Ultra...
The S24 Ultra Display is very bad & Worst Display even when you compared to S23 Ultra also...
Even Samsung Service Centers also unable to fix this issue.
it's BIG ISSUE in a Samsung S24 ULTRA Flagship Mobile But Samsung was Unable was not taking this issue very Seriously and Fixing it !!!!
Even 10 thousand mobile we can use as much as time in Sunlight and it's Display is Super in Sunlight...
But Purchasing S24 Ultra Flagship Mobile of Samsung with Lakhs of Rupees But Unable to Use for even 5 minutes in Sunlight...
This is Very very BIG ISSUE in the Samsung Flagship Mobile S24 Ultra.
07-08-2024 04:39 PM in
Galaxy SEven I face the same issue...
And no questions about over heating.
Heats even in normal usage scenarios. If we use camera, it's like a pan above fire....
And the display dimming issue , It bothers a lott when going out.
07-08-2024 04:40 PM in
Galaxy SNot Fixing many issues
07-08-2024 06:32 PM in
Galaxy SWe are just single user.
07-08-2024 07:39 PM in
Galaxy SCan you share a screen shot?
07-08-2024 08:25 PM in
Galaxy S- Mark as New
07-08-2024 08:35 PM in
07-08-2024 08:21 PM (Last edited 07-08-2024 08:22 PM ) in
Galaxy SInstall Good Guardians modules in that I don't remember exactly which one but try Thermal/Battery guardian .One of them have a brightness related setting as per your issue .
If you can't install upper modules from Galaxy store try with fine lock from playstore .
Also you firstly need to install goodlock and
Good Guardians , GG Agent to run those modules mentioned above.
Tell me if this works or not.
07-13-2024 09:53 PM (Last edited 07-13-2024 09:53 PM ) in
07-14-2024 09:12 AM in
Galaxy SAnyway I didn't expect this to work flawlessly as I said it's a work around.
