09-26-2025 10:18 PM (Last edited 09-26-2025 10:18 PM ) in
Galaxy S- Mark as New
09-26-2025 10:31 PM in
09-27-2025 12:18 AM in
09-27-2025 06:32 PM in
09-28-2025 10:08 AM in
09-27-2025 10:22 AM in
Galaxy SDear Samsung member,
9. Reset the device:
IMPORTANT:
• If you do not remember it, then reset (Forgot password) your google account.
• For this:
• Open Gmail (https://accounts.google.com/servicelogin) > forgot password >Select ""try another way"" > Next > Enter a new password > Next.
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tab on Factory data reset (This will erase all data, including files and downloaded apps)
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send).
09-27-2025 07:33 PM in
09-27-2025 07:26 PM in
Galaxy SSame here after one ui 8 I'm hardly getting 5 hrs sot which is way worse and just after taking it off from charging 10% drains within few mins very disappointed from samsung
09-28-2025 10:13 AM in
Galaxy SEdit: after some suggestions i Tried switching off personal data intelligence under the privacy and also now brif it has drastically improved my battery life
