S24 plus call issue
(Topic created on: 09-17-2025 10:57 AM)
Haritom
Beginner Level 3
I am using s24 plus for past 7 month. Dor last 2 months i am facing call issue. When i call same one suddenly call we cut off and if the person attend the call then the call will cut off. Its really bad #samsung. Kindly fix this.
5 Comments
goodthings
Kindly complaint to Samsung customer care support through Samsung Members App as error report also send log files along with this error report for this issue and wait for next update it's maybe fix by Samsung team soon. If you like please accept it's as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
Haritom
Beginner Level 3
goodthings
You're welcome.
goodthings
You're welcome to here.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that it can happens due to network glitch. Meanwhile, kindly perform the following steps to resolve your issue by the given link:
● Call disconnect issue: https://www.samsung.com/in/support/mobile-devices/what-to-do-when-your-galaxy-device-is-unable-to-ma...
3. If you do not remember password then advise to reset (Forgot password) your Google account.
