S24 plus Fast Battery Draining
(Topic created on: 07-18-2025 02:09 AM)
Angshuman4
My samsung s24 plus's battery is draining fast. I tried all the possibilities to fix the battery backup like factory reset, limiting some apps, dark mode on, light performance profile, disabling some settings etc. but there is zero improvement. This is due to the faulty and less optimized software (ONE UI 7). Currently my phone got the new july security patch. Even in this update, there is no improvement of battery backup. Please fix this issue.
15 Comments
SUDIP2003
How much SOT you are getting?
Angshuman4
4-5 hr
DennisRulz
😂😂welcome to the club mate !!
BiRdMaN
Send an error report along with log files to customer support through this members app and Samsung will fix it in the next update. To do that follow this procedure
Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
If you find this helpful I'd appreciate it if you could Accept it as a solution Thank you 😊
Angshuman4
Done
nastawal
Well the battery life has taken a hit after the latest july patch
Angshuman4
What do you mean? Increased or decreased
nastawal
Decreased
Angshuman4
Sme sme
