S24 battery drain issue
(Topic created on: 10-13-2024 07:51 PM)
s24user1
S24 battery began to drain fast as superfast train when using 5g outside even not in hot climate.using orginal 25 watt samsung only .Please bring a better update for battery backup.if capable increase brightness for this phone in outdoor not good as expected old phone is better with 1000 nits than this 2600 nits outside.
2 Comments
sdeepuhg
I'm also facing this battery drain problem with my S24 Ultra.
cs_member10
Dear Samsung Member,
As per your concern, we want to inform you that while using 5g networks due to higher power consumption and heat generation phones may consume more battery than usual. Therefore, if the phone is connected to multiple networks at the same time, the battery may drain faster than you would typically expect, and the phone may get a little warmer than when solely on 3G or LTE. However, we are taking your valuable feedback regarding drain issue. we are continuously working to make our products better and more efficient.
● Kindly perform the following steps by a given link to resolve your battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
