S24 Ultra Sunlight display issue
(Topic created on: 04-28-2024 12:26 PM)
RAMULTRA24
Hi,
Unable to use even 10 minutes in Sunlight,
After using mobile for 3 minutes or so the Screen is getting Over heated & Unable to see the Display as it will become Dim after that it will become Normal only after you go it Indoor..
 it's Big Issue in a Flagship Mobile...
I visited Samsung Service Center, they tried
1.IQC---No Problem in it,
2.They Done Software for it---No fixed the issue
Buying Mobile for Lakhs of rupees But Unable to Use it even 10 Minutes in Sunlight Displayyyy
Facing this issue from Many days, Unable to Find Solution & Fix it...
See below video once
What to do now ????
22 Comments
Pallav0024
Sad to hear this from a flagship level phone....any other 24 ultra users try using ur phone on sunlight for 10 mins minimum and give ur feedback here
Ultra_Devil
Yes it's a flagship level, and don't compare or test in weird conditions.. phone said to be water resistant, not to be a solar phone to use in bare sunlight... 😂😂😭😭
am100
Y not taking replacement?
Ultra_Devil
Why would he need replacement,I think you need to understand the tech before suggesting such suggestions.
am100
Before judging others n passing judgments, i guess u need to share ur qualifications.1714302014416.gif
Ultra_Devil
See again, you asked for something which doesn't require here.. this shows how relevant you are to the queries.. 😂😂😭😭
am100
Ultra chooteeeyaa, dusra replacement lera teri kyu jalree chooteeye, bina kaaran gyan dera n comment kar rha dusre ki knowledge par bina ye bataye tu hai kon chooteeeyee. 1714305131371.gif
Ultra_Devil
I knew it.. How knowledgeable you are, you just shared in your comment.. thanks mate for showing your knowledge...
And in your language, #KadakChutiye, kisi ki hope create kyu karni ki replacement le lo.. tum jaise **bleep** khud to mendhak rahenge or dusro ko bhi yahi banaye rakhna. Chahte..
RAMULTRA24
Samsung team not responding properly But I am trying for Best Solution from them...
From Many days I am facing this Issue and I am so disappointed 😞 😔 😕
