S24 Ultra Not Getting Enough Battery Life
(Topic created on: 05-15-2024 09:32 PM)
sintosun
I've noticed a significant difference in battery performance between my S24 and those of other users. Many posts from fellow S24 users mention they're easily getting around 10 hours of battery life, which is quite impressive. However, my experience has been quite different. Even with what I consider to be normal usage, I'm only able to manage 5-6 hours of battery life at best. This is particularly surprising to me because my phone is relatively new; I recently purchased it. I've also made sure to stay up to date with the latest software, currently running on the April Security Patch Update. Despite these efforts, my battery performance remains subpar compared to what others are reporting. I'm curious about your experiences. Are you facing similar challenges with battery life on your S24, or have you found any tips or tricks to improve battery performance?
19 Comments
Bro.. they bluff.. and this is why British came in India and ruled.. becoz of these sort of people only..😂😂😂
I keep my phone in dark mode 20% brightness
All flagship phone S U C ks
Sravan_
Sravan_
Sravan_
arunnechlani
sag120667
Same here. Seems 6.1 is draining battery. I have s24 and it gives me 4-5 hours SOT. My wife's s23 used to give 8-9 hours of SOT but after upgrade to 6.1 she is getting 3-4 hours sot only.
cs_member10
Dear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by given links.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
huntinglite
S24 ultra max to max 5.2 or .5 battery life standby is also **bleep** everyday battery discharges around 8% without even using it no bg apps running and in power saving mode before update it was good ig only been 2-3 months using this my friends s23 ultra have better battery life then this1732376475332.jpg
