S24 Ultra 5g not working for Reliance Jio
(Topic created on: 01-26-2025 07:17 PM)
rk_crunchyArcher
Hi,
I recently bought s24 ultra from USA. Ordered it directly from Samsung website . but after few months when I moved to Indiacannot use 5g I am using Reliance jio, checked in internet the phone has necessary hardware like 5g bands. I went to Samsung and jio both are of no help pushing blame on other Party
need help Please
its very expensive device.
Thanks
My Aim for asking the question was to get some trick/**bleep** to get jio work on my phone. Sooo sorry i cant mark it resolved. I will like the comment. Thanks
RAHULA34
Try this options below:-1. Use jio app to register your jio number for 5g service. 2.Go to jio service centre tell them your problem but don't tell your mobile phone is purchased from USA. They do some bypass tricks to give you 5g connection.3. If any old mobile store near you go their and ask some tricks they are well know about that.
If your problem solved then let me know. sorry for advanced.
What bypass trick??
RAHULA34
Specially i don't know but they register your device as Indian product in jio server. So the 5g work well.
goodthings
You are absolutely right now. Jio true 5G network not works with your device due to it's out of India variant so please use Airtel 5G network. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
Bypass Trick Won't Work on Telecom Network Sim card
If u purchase Smartphone in India then work fine
If u purchase Smartphone Outside Country Then Jio 5G Service No Longer Work Anymore As Per Jio Said
If u like plz accept as a solution it's help to others users also , Click on 3 dots in my reply section and click on accept solution thanks
Ohhh ok. Thanks man . Appreciate your response 👍
Kindly accept my solution
Jagdev000009
It's samsung problem, i have s24 canada version, same problem, no jio 5g working, samsung block network band, that's why all blogger use iphone, #samshit
