S24 Audio issue
(Topic created on: 07-26-2024 11:34 PM)
3kesh
The audio on the s24 is so bad. Voice just crack. Never had this problem with the previous versions. Mine being the s20.
Anyone else face this issue?
9 Comments
NOMAĐ
Voice cracks on calls or while listening music?
3kesh
Music
NOMAĐ
I listen to music all day with 80 to 90% volume level. I dint find any voice cracking.. Using S24 base. Either the music files are at fault or must be the speaker. Get your device checked.
Maybe there is an issue at hardware level.
goodthings
goodthings
Your's most welcome to here.
NOMAĐ
Bro.. why do you accept sending error report in members app as a solution? Did that rectify your voice cracking issue?
3kesh
I dont know. Maybe thats an issue at the default level so I did
NOMAĐ
Bro.. good things sends you copy paste content thinking that it's a solution. He sends the same to everyone. He doesn't even listen to your concern and shamelessly will ask you to accept that as a solution.
What is the solution to your problem. Does sending error report to samsung rectified your issue?
Don't encourage him by accepting this as a solution bro.
cs_member10
Dear Samsung Member,
As per your query, we request you kindly share the log file. Also, share video clips and images for better understanding. This will help us to further investigate and resolve this issue.
Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
