S23fe network problem
(Topic created on: 10-27-2024 08:26 PM)
dhiva
I have useing s23fe i am using network in jio 5g
Very worst .
Please help in samsung team
This problem only samsung device
9 Comments
hiimansh111
Reset Network setting and check .
dhiva
I am already this method used 🙏
hiimansh111
What problem exactly are you facing..?
goodthings
Lower 3 lines copy of my words and same sentences.
SSFanboy
Iam also seen same network issue in S21 fe model, maybe it is area network issue , some time 5G network not get properly so this time I shift my phone network in to aeroplane mode then it comes to normal i get 5G network back.
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and wait for next update may be fix it by Samsung team soon. If you like please accept as a solution it's help to others users also,click on 3dots in my reply section and click on accept solution. Thanks.
goodthings
Your's most welcome to here.
AbHaY0
What happened
cs_member10
Dear Samsung Member,
As per your concern, we would request you to kindly visit this mentioned link to resolve your issues.
● Galaxy device network issue: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-smartphone-how-to-optimise-network-...
In case the issue still occurs, kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
