S23fe Auto sync problem
(Topic created on: 05-04-2026 11:28 PM)
yashk2006
Account sync is off tap here to turn it on is message ko kese band kare please muje kohi bata O or YouTube video hoga to please share me link nahi to kohi video kar ke bhej do band kar ne ko message
3 Comments
MUHAMMADkAIF
Ye band nahi hoga kyu ki tum samsung cloud pe contact save karte ho shayad
yashk2006
Nahi me mere Google account me karta hu
cs_member10
Dear Samsung Member,
Sync your data to the Samsung cloud
Note: Content will not automatically sync if your Cloud storage is full. Data charges may apply if the "Wi-Fi and mobile data" option is selected.
Navigate to and open Settings, tap your name at the top of the screen, and then tap Samsung Cloud.
1. Tap an app to see its additional sync settings. To change the sync settings, tap Sync using, and then choose Wi-Fi only or Wi-Fi and mobile data.
2. Next, tap the switch next to your desired apps and data to turn auto sync on or off for them. Some apps you can sync include Contacts, Calendar, and Bluetooth.
3. If you want to manually sync everything right now, tap Back up data, and then tap Back up now.
Paras Awasthy
Enabling Auto backup or Syncing your data manually also ensures that your Cloud storage account is safe from deletion. Any accounts or categories such as contacts, calendars, keyboard data, etc. that are not used within 12 months could be subject to deletion.
If the issue persists, kindly report the problems with a log file. To share a log file, Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
