04-30-2025 09:23 AM (Last edited 04-30-2025 09:26 AM ) in
Galaxy S- Mark as New
04-30-2025 09:30 AM in
04-30-2025 09:34 AM (Last edited 04-30-2025 04:34 PM ) in
Galaxy SAlso SOT also seems decreased.
Still under monitoring now just 24 hrs experienced after update.
04-30-2025 04:36 PM in
Galaxy SDear Samsung member,
Please perform the below-mentioned troubleshooting steps, these may help in resolving your concerns.
▶ Galaxy device Battery drainage issue: Note: Charge in one go instead of charging many times as it affects the life span of battery and battery performance.
2. Check device network fluctuation.
3. Adjust screen timeout settings: Go to Settings > Display > Screen timeout > Select the minimum screen timeout.
4. Check which application is or interface is using more battery from device care and try to update app or avoid using that app.
6. Turn off auto sync of e-mails, app data etc.
▶ Galaxy device heating issue: 1.Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
2. Decrease the screen brightness.
3. Close background running apps.
4. Uninstall the unnecessary apps.
5. Reduce long duration of graphics intensive gaming sessions as it may cause heating issue.
6. Avoid usage of mobile phone when charging.
7. Reset the device:
IMPORTANT:
• For this:
Please follow the below steps to reset the device: Settings > General Management > Reset > Temporary cloud backup or External storage backup > tap on Factory data reset (This will erase all data, including files and downloaded apps)
If the heating and battery drain issues persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send).
▶ Charging Adaptor issue: ● Make sure to connect the charger to a working power socket.
● Check the main socket by connecting any other appliance.
● Check whether the connected device is working fine or not.
● Check your charging cable and power adapter for any signs of damage, like breakage or bent prongs (3 pins of the adapter of the charger of your mobile device).
Note: We recommend using a genuine Samsung charger and charging cable that you receive with a Samsung device.
● Remove the charging cable and reconnect with a mobile phone. If the mobile phone doesn’t charge then check with another charger (If available).
Note: Examine the charging port & charging cable to ensure there are no foreign objects blocking the charging cable.
In case the issue still occurs, please visit the service center for a physical inspection of your device with charger and charging cable. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
04-30-2025 05:09 PM in
