S23 ultra, notification sound not stopping until I restart
(Topic created on: 04-06-2024 01:15 PM)
chiku2706
Whenever I use my Sony headphones with my phone, and I receive any notification, the notification sound doesn't stop at all. It keeps on ringing even if I disconnect my headphones.
Then it only stops when I restart the phone. Anyone else facing this issue?
4 Comments
Swapnil12038
Beginner Level 4
Yes. Same issued is faced in S10+ too
chiku2706
Hey Swapnil, is your issue resolved? I'm still facing the issue
cs_member9
Dear Samsung Member,
As per your query, please follow the troubleshooting steps to resolve the issue: -
Restart the device:
Press and hold the Power and Volume buttons down simultaneously for more than 7 seconds to restart it.
Reset app preferences: Go to, Settings > Apps > Tap on More option > Tap on Reset App Preferences.
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Samsung Customer Support.
chiku2706
Hi team, the issue is not getting resolved. I belive it's a software issue because I'm not having this issue with any other bluetooth device. It only happens with my sony headphones.
