S23 ultra heating and battery drian
(Topic created on: 04-13-2024 08:52 PM)
NanduNanduzz
After the 6.1 update, the device is getting hot and the battery is draining quickly.
8 Comments
Most issues will be fixed by the next update, like what happens with the s24 ultra
NanduNanduzz
I have already done the April update.
I mean, update fixes major of problems
NanduNanduzz
AhmedZakut
It didn't fix the Auto Hotspot issue. Every time i am trying to connect to the internet from my tablet to the S23 Ultra, the auto hotspot switches off. Never faced this issue before one ui 6.1
UmairD
Same here
NanduNanduzz
Samsung_specialist
We apologize for this, you may try these steps :
- Turn off the Wi-Fi, GPS, Bluetooth, and other connectivity when not in use.
- Avoid using maximum screen brightness.
- Close unused applications.
- Avoid using apps on mobile data and playing graphic-intensive videos or games for a longer duration.
- Always use a genuine Samsung charger for your device.
- Avoid using your phone while charging.
- Uninstall unused applications from the device.
https://www.samsung.com/ae/support/mobile-devices/is-it-normal-for-galaxy-phone-to-heat-up/
