AI Problem
(Topic created on: 04-13-2024 11:07 PM)
imabhii
Hi guys, when I try ai feature in S24 ultra it's not working always showing this error pop-up. Can anyone tell me what's the exact issue.
6 Comments
Ahamed7
I have the same issues, and then all the samsung Galaxy apps are not working it's showing something went wrong. Do you face the same problem?
imabhii
No bro, only this issue. Now it's fixed.
Ahamed7
How did you fix it
imabhii
Goto Advanced intelligence and try disable process data.
And you required a good network connectivity it's working fine now.
Samsung_specialist
Please be noted that some AI feature my need good and stable internal connection.
You may try the safe mode:
Reboot the device if the issue is not resolve you may raise error report for this https://www.samsung.com/ae/support/mobile-devices/raising-an-error-report-via-samsung-members-app/
