Resolved! Solved
S23 ultra call not recording
(Topic created on: 09-06-2023 02:30 PM)
spraveen
Can any body tell what is the procedure to start call recording in s23 ultra.
Thanks
ParagU
Dear from which country you are? As call recording is not enabled for every country. It is configured market wise where the mobile is being selled. Like in indian handsets it is enabled
9 Comments
In call settings there is a tab record calls click on that it will open record calls section in that enable auto record calls that's it it will start recording ur calls
spraveen
There is no tab option
First go to call settings u will find thisScreenshot_20230906_151038_Call settings.jpg
Than click on record call u will get this tabScreenshot_20230906_151111_Call settings.jpg
There on auto record calls ur phone will start recording calls
U can also on show notification after recording which will show u notification after recorded call this feature helps u delete that recording if it's not useful to u
ParagU
S23ultra any app call recording please tell me
Can anyone tell me a good call recording app for S23Ultra? Please tell me sir....🙏
