12-17-2024 11:49 AM in
12-17-2024 05:15 PM in
Galaxy SDear Samsung Member,
We regret to hear about your experience with our product.
To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
You can reset your device by following the steps:
3. If you do not remember then reset (Forgot password) your Google account.
If the issue persists, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> select the appropriate issue category> Type your query and send.)
