S23 Ultra- wifi calling issue.
(Topic created on: 09-07-2023 05:21 AM)
S_Kumar73
Enabled Wi-Fi calling and sometimes when we receive a call and attend that call, the call screen comes but not getting connected and in the top it shows incoming call only. The only option is to disconnect the call screen and need to call that caller.
I still in one ui 5.1 and not updated to one ui 6 beta. So no idea the issue is there in beta.
8 Comments
Maybe the wifi's internet speeed is slow
And the thing is yoi enabled wifi calling
But why its not vowifi there?
S_Kumar73
Do you think this is Slow wifi?SmartSelect_20230907_070437_Speedtest_1000210481_1694050477.jpg
I just assumed , you can just say no wifi is good
And you turned wifi calling for sim 1 only?
S_Kumar73
For airtel the icon look like that only.
Please give a screenshot of status bar
No see actually for jio as it support wifi calling showing jio wifi
But bsnl doesn't support so showing nothing Screenshot_20230907-071042_Wi-Fi Calling.jpg
S_Kumar73
I didn't turned on wifi calling for jio because the network strength for Jio is high. Only airtel network signal is weak. So I turned on airtel only. For airtel the icon shows like that. For jio it will show vowifi.
S_Kumar73
Now you can see. For jio it shows Vowifi. And for airtel it shows different. Screenshot_20230907_075310_Wi-Fi Calling.jpg
cs_member8
Dear Samsung Member,
We acknowledge your query and want to inform you that to use Wi-Fi Calling, you need to insert an active SIM card from a carrier that supports this feature. Check with your network provider if your SIM card is supported, and contact your network service provider they will guide you to the exact information regarding this.
