S23 Ultra | Samsung health running in background. HOW TO STOP
(Topic created on: 08-14-2024 08:58 PM)
GOWTHAMGJ
Hi
I had recently connected & initialized samsung health on my mobile earlier, I had been tracking my health data directly from my Galaxy Watch 4 Classic. Then, it wasnt an issue. But now i Accepted terms and conditions of SHealth on my device, I am getting a notification Samsung Health is running to measure your health data."
I want this background service to be stopped specifically from "shealth" and not the notification to be turned off or restrict it from battery usage, I need this to be turned off from "Shealth".
 Kindly help me with steps. Thanks
4 Comments
Gouthamram
Just disable it
arusha1234
Kindly go to settings then apps then s health then battery then select restricted.
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly follow the given steps if you want then you can disable the Samsung health app from the background activities through setting of your device.
Path : 1. Go to Settings > Apps, select the app from the list, and tap App battery usage.
2. Then, tap Force stop to shut it down, or switch off Allow background usage to prevent background activity.
3. To see apps running in the background, go to Settings > System > Developer options > Running services.
However, If you have other concerns regarding Samsung products kindly feel free to get in touch with us if there is any issue regarding the Samsung.
GOWTHAMGJ
Is it not possible to disable from shealth app itself. I just want to disable it from shealth and not from background usage. I had already requested that on my post. If there is a step inside samsung health. Please help
