04-29-2025 09:33 PM in
Galaxy S- Mark as New
04-29-2025 09:37 PM in
Galaxy SMy next suggestion was to wipe cache but for that user, it did not require.
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved".
04-29-2025 10:02 PM in
04-29-2025 10:11 PM in
04-29-2025 11:28 PM in
04-30-2025 11:12 AM in
Galaxy SDear Samsung Member,
At Samsung, we strive to ensure you have an excellent product experience. Our products undergo stringent global quality checks and currently, there are no reported issues.
Please follow these easy troublshooting steps which may help in resolving this issue if you are facing on your device.
● Disconnect anything plugged into the headphone jack like, a selfie stick, headphones, Bluetooth, etc.
Remove any third-party case, protective films, or any other accessory that usually comes in contact with your device.
● Check device volume settings: Tap on Settings > Sound & vibration>Volume > Drag the volume adjustment bar left or right to increase or decrease the device volume.
To verify, play music and check the music sound. If the sound quality is good, then your speaker is working fine.
● Clear Sound Picker data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Picker> Storage> Clear data of Sound Picker.
● Clear Sound Alive data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Sound Alive> Storage> Clear data.
● Clear Adapt sound data: Settings> Apps> Filter and Sort> Enable Show system apps> OK>Search Adapt Sound> Storage> Clear data.
● Reset app preferences: Settings> Apps> Three dots> Reset app preferences> Reset.
3. If you do not remember password then advise to reset (Forgot password) your Google account.
