S23 Ultra Keeps Switching to LTE Under Heavy Data Usage - Forced 5G Fails
(Topic created on: 01-14-2025 09:07 PM)
Jstar_Makwana
I'm using an S23 Ultra, and I've noticed that whenever there's heavy data usage (like downloading large files via a hotspot), the phone automatically switches from 5G to LTE.
I tried forcing 5G using a 5G app, but when I do, the phone loses signal entirely, and the SIM gets disabled until I restart the device. This is frustrating because I rely on 5G for faster speeds, especially when tethering.
Has anyone else experienced this issue? Any solutions or settings I can tweak to fix this?
Kamaleshganu
Brother, your application is correct, but under NR mode, it will ask you to turn on a radio mode, turn it on. 1736870856012.jpg1736870856079.jpg1736870856171.jpg
Jstar_Makwana
It's on
Kamaleshganu
That's called By force 5G Mode and it will only have 5G mode but there will be a slight problem with phone calls.. You will use it for as long as you want and then use it normally. 1736871110623.jpg
Kamaleshganu
KINDLY ON MOBILE RADIO POWER NR MODE is written below
Wodehouse
It seems like you're experiencing network issues with your S23 Ultra, specifically with it switching from 5G to LTE during heavy data usage. This issue has been reported by other users, and it's possible that it's related to the phone's network settings or a software glitch.
To resolve this issue, you can try the following:
- *Check your network settings*: Ensure that 5G is enabled and selected as the preferred network type. You can do this by going to Settings > Connections > Mobile networks > Network mode.
- *Use the hidden testing menu*: Dial _#_#4636#_#_ to access the testing menu, then select Phone information and scroll down to Set preferred network type. Choose NR Only (5G Only) from the dropdown menu.
- *Install a third-party app*: Apps like NetMonitor or 5G/4G Force LTE can help you lock your phone to 5G only. However, be cautious when using these apps, as they may cause network issues or affect call quality.
- *Check for software updates*: Ensure your phone is running the latest software version, as updates often resolve network-related issues.
- *Reset your network settings*: Go to Settings > General Management > Reset > Reset network settings to restore your network settings to their default values.
Keep in mind that forcing your phone to use 5G only can affect network reception and call quality, especially in areas with limited 5G coverage.
Please check these links too
https://r2.community.samsung.com/t5/Galaxy-S/5G-Not-working-in-s23-ultra-after-June-Update/td-p/1410...
https://gadgetstouse.com/blog/2024/09/17/force-5g-only-on-android-phone/
If this reply answered your query please tap 3 vertical dots to the right of my reply and tap "Resolved". Thank you 😊
Kamaleshganu
I have tried many things but nothing worked and I have to face the same problem. Please tell me if you know any new way.
mnh
Well the fact is 5g service are not strong that why it's switching to lte . Use lte when you are indoors
Kamaleshganu
Use the best 4G LTE mode only application and turn on 5G Mode or NR mode or turn on one of the RADIO Power modes below and use it as much time as you want and you can make it Normal if you want.
jabaganai
My S24....same issue
Wodehouse
The issue you're facing with your S23 Ultra switching from 5G to LTE during heavy data usage, especially when tethering, is a common one. Here's a breakdown of why this happens and some potential solutions:
Why it Happens:
* Network Congestion: When you're using a large amount of data, especially through tethering, it can strain the 5G network in your area. To prevent network overload and ensure fair data access for all users, your carrier might automatically switch your connection to LTE.
* Signal Strength: 5G signals are generally more sensitive to interference and obstructions than LTE signals. If your 5G signal weakens during heavy data usage, your phone might automatically switch to the more stable LTE network.
* Phone's Thermal Management: High data usage can generate heat in your phone. To prevent overheating, your phone might prioritize heat dissipation by switching to LTE, which consumes less power and generates less heat than 5G.
* Carrier Throttling: Some carriers have data usage thresholds. If you exceed these limits, they might throttle your connection, which can cause your phone to switch to LTE.
Potential Solutions:
* Check Network Coverage: Ensure you're in an area with strong 5G coverage. Use a network speed test app to check your download and upload speeds on both 5G and LTE.
* Restart Your Phone: A simple restart can sometimes resolve temporary network glitches and improve signal stability.
* Contact Your Carrier: Explain the issue to your carrier's customer support. They might be able to provide insights into network congestion in your area or offer solutions like a data booster or a higher data plan.
* Optimize Data Usage: Consider reducing data usage during peak hours or when tethering. You can also prioritize data-intensive tasks for times when you're connected to Wi-Fi.
* Consider a 5G Booster: If you frequently experience weak 5G signals, a 5G signal booster might improve your connection strength.
Important Note:
* Forcing 5G using third-party apps can sometimes interfere with your phone's network settings and cause unexpected behavior, such as the SIM getting disabled. It's generally recommended to avoid using such apps unless you know what you're doing.
I hope these tips help you resolve the 5G switching issue and enjoy faster speeds on your S23 Ultra!
