S23 Ultra. Call mutes in between and dialer hangs on disconnecting
(Topic created on: 10-11-2024 09:21 PM)
irajnish
I have bought this s23 ultra on phone on 27th September. And have been facing this issue from the beginning.
Before this I was using s21 fe snapdragon 888 version and I faced the same problem in that too.
Here is the issue I face repeatedly :-
While a call is going on suddenly both of us are not able to hear each other's voice.
And when I try to disconnect the call it stucks on the attached blank screen for few seconds (this does not happen normally.)
5 Comments
goodthings
Kindly complaint to Samsung customer support through Samsung Members App as error report also send log files Along with this error report for this issue and go to service center for resolves this issue. If you like please accept as a solution it's help to others users also, click on 3dots in my reply section and click on accept solution. Thanks.
irajnish
Yes. I've complained already.
goodthings
Your's most welcome.
goodthings
Your's most welcome to here.
cs_member10
Dear Samsung Member,
● Check app Cache: Settings> Device care> Storage> Clean now.
● Clear cache memory of a particular application: Settings> Apps> Now pick the app that you like to clear off the cache memory> Storage> Clear Cache.
● Keep your apps updated: Galaxy Store apps: Open Galaxy Store, tap the Menu (the three horizontal lines), in the upper left corner, and then tap Updates. From here, you can either tap the circling arrow next to individual apps to update one at a time or tap Update All to install all available updates.
● Play Store apps: Open the Play Store, tap, and then tap your profile picture. Tap My apps & games. From here, you can either tap Update next to individual apps or tap Update All to install all available updates.
● Kindly check network on your device if it is properly working on device.
● Kindly reset the network settings. Settings> General Management> Reset> Reset Network Setting.
● Kindly check the same SIM card in another phone or another SIM card in the same phone to verify the issue.
● Update device software (If available): Settings > Software update > Download and install > Checking for software update > Software update available > Download > Downloading updates > Install now.
