S23 ULTRA I NEED ADVICE
(Topic created on: 05-12-2024 02:40 PM)
ashlly
I'm reaching out for your advice and help! After updating my S23 Ultra to version 6.1, I've noticed a strange issue. When I enable: - Light mode - Adaptive motion - QHD+ screen resolution My phone overheats excessively. This wasn't a problem before the update. I've tried resetting my phone, but the issue persists. Currently, I'm stuck using normal settings with HD+ resolution to avoid overheating. Has anyone else experienced this issue? Any suggestions or solutions would be greatly appreciated! Thank you in advance for your help!
14 Comments
RAGED
Have you tried the "Optimise now" feature in Battery and device care settings to manage device temperature and performance. You can also add the Optimise now widget to your home screen to get quick access when you need to optimize the device anytime.
ashlly
Yes I tried but still the same
ashlly
Yes, I tied that, and it's still the same, even using WhatsApp
TeeA
Can you still use the QHD+ without the light mode? Does it overheat?
ashlly
Let me try this now because it always heat very fast and come back
ashlly
What about motion should I use adaptive or standard
TeeA
Try adaptive first and see
ashlly
So adaptive with QHD+ without light mode right?
TeeA
Yes
