01-22-2024 05:46 PM in
Galaxy S- Mark as New
01-22-2024 05:56 PM in
01-22-2024 07:19 PM in
01-22-2024 07:10 PM in
Galaxy SNetwork issue and battery drain after Jan update
01-22-2024 11:22 PM in
01-23-2024 08:57 AM in
Galaxy SDear Samsung Member,
As per your concern, we would request you kindly perform the following steps to resolve your issue by given links. However, we are taking your valuable feedback regarding this.
Galaxy device Battery drain issue: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-...
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
You can check the device in safe mode and for the same mode you can tap on the given link. https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
In case the issue still occurs, kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
02-07-2024 11:04 AM in
02-08-2024 11:30 PM (Last edited 02-08-2024 11:30 PM ) in
02-08-2024 11:37 PM in
