S23 Frame rate issues
(Topic created on: 10-02-2025 07:47 PM)
Achuarjun
Does anyone have frame drop or stuttering while taking videos in s23
5 Comments
Is it during low light?
Achuarjun
Nope day time mostly.
Strange. I would say clear cache/data of your camera app.
Wipe cache partition of your phone and try.
Before that try disabling auto fps and check.
Achuarjun
Thank you
cs_member10
Dear Samsung Member,
We request you kindly share the log file. Also, share the video clips and images for better understanding. This will help us to investigate further and resolve this issue.
To share the log file: Open Samsung Members Application > Support> Tap on send feedback> Choose Composer> Select error report> Select the appropriate issue category> Type your query and send.
