S23 FE heating and battery issue
(Topic created on: 10-11-2023 01:22 AM)
pịkachu
Is anyone facing battery draining and heating on s23 fe?
18 Comments
vivek1989
Wait kro abhi launch straight away mt bolo battery issue
Let allow ui to settle for atleast 1.5 weeks.
pịkachu
Ok
YashChauhan7
Bhai maine 2 din phele liya and phone bohot heat maar rha hai
Thik ho jaega ye??
pịkachu
Getting better, still lot to improve
cs_member10
Dear Samsung Member,
Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
Galaxy device battery drain issue:
Charge in one go instead of charging many times as it affects the life span of the battery and battery performance
Perform Battery Optimization
Settings > Select Device Maintenance/Device Care/Battery and device care > Optimize > Optimize all options like Battery, Storage, and Memory
Turn off Wi-Fi, GPS, Bluetooth, etc.
Turn off unused functions like Wi-Fi, GPS, Bluetooth, and location settings when not using them: On the home screen swipe down the notification panel > Turn off Wi-Fi, GPS, Bluetooth, and other connectivity features when not using them.
Check device network fluctuation
Kindly check whether the mobile network fluctuates frequently or if the network signal is low in your area. In both cases, the battery will drain considerably fast.
Recommendation: We recommend you avoid using it in areas with low network/fluctuation.
Reduce display brightness level
Kindly set the device display brightness in auto mode (If available).
Adjust screen timeout settings: Settings > Display > Screen timeout > Select minimum screen timeout.
Check and update the App: Kindly check which application or interface is using more battery from device care. And try to update the app or avoid using that app.
Close background running apps
Close all the background running apps when not using them,
Turn off auto sync of e-mails, app data, etc.
We request you turn off the auto sync option, it will stop the synchronization of the device with the server & reduce the battery drainage.
The steps to turn off auto sync are:
2. Turn off the auto sync option.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
In case the issue still occurs kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
Members_5TDcwNE
you are asking basically to turn off everything - so fundamentally 65k worth phone with no use- less than half price dont have any problem with everything turned on.
Samsung_j2Cb7qx
Beginner Level 4
Facing the same issue. Too much overheating and battery draining fast.
saurabh97
Yes facing same issue
newton_m
Yes I am also facing the same issue when start to using camera.does any find the solution?Screenshot_20231021_150801.jpg
