S23 FE Battery issue
(Topic created on: 10-24-2023 08:10 PM)
sof9
Samsung has advertised long lasting battery in its adds related to the product. But I am hardly getting 4 hrs screen on time and total charge not lasting even until evening
But When asked about the battery issue of the product , they are asking to turn off the AOD , lower refresh rate and switch on battery saver and minimise brightness.
This is quite a costly product which i took with some expectation to have a smooth , quick experience.
Samsung necessarily have to optimize the software and processor to get better battery life
10 Comments
You are right.....I also facing same on my Galaxy M34 5G, after factory reseting it 2 times....I'm facing many issues like automatic touch, hang, heat etc
Just do these simple steps first.
1) Make your rarely used apps in deep sleeping mode so they will not be able to run in background.
2) keep it at 60Hrz
3) Don't charge it above 85% and below 20%
4) Check app and software updates.
5) Always Optimize your Galaxy at Device Care application in settings.
6) Decrease Brightness
HeyReviewPro
Share ss
pramodn85
My friend, all of their series have this same issues. Even snapdragon also has same battery drain issue (S23/S23 Ultra) people posting battery issues a lot. Coming to S23 FE yes there is a way to reduce this battery drain like turning off AOD, Brightness, Animations to none in Developer options etc., at some extent we can save the battery.
But the said things are useless when you connect the internet. This will quickly drain your battery, i dont think if you even get 2 hours while connected with internet (Wifi/Mobile data).
We people are fools who go for flagships and choosing Samsung brand who cheats us in all the ways.
I have oneplus device in my family they are far far better when it comes to battery. Even Realme also good in battery when comparing to Samsung.
Only way that we can expect is to sit with fingers crossed🤞 if they think customer is king then Samsung will surely rollout the fix through OTA updates else they will lose whole lot of customers from India region for sure for their next S series.
sof9
Hoping so😅
suriyavg123
Hii . I also bought s23 fe and have been using it for 15 days .At first I didnt get enough battery backup . After a week it automatically learned the pattern and put some app to sleep .Now I am getting good battery backup.Today morning took out of charger at 93% and now it around 20 percentage with abv 4.5 hrs screen on time with all time wifi 5g,bluetooth ,GPS on .But I don't generally like aod , so it is off .So better wait for a week .hope this helps
sof9
Yes Battery its cool
There is an improvement i think Do you have heating issue in any apps ?
For me Amazon and flipkart use heats it up
suriyavg123
Yes , It do heat up lightly few times .its not like big issue for me.but its now better than first week
junaid0003
I switched from vivo to s23 fe feeling regret now, worst battery lasting, heating issue.
Battery is draining so fast..even after one time full charge.
sharad_112
My new s23fe last 5% charging is draning so fast like in just 5 min phone is getting off is it Normal?
