S23 FE BATTERY ISSUE
(Topic created on: 2 weeks ago)
Nityanand23
I've noticed that my S23 FE's battery is draining faster now that the outside temperature is high, resulting in less screen time.
3 Comments
cs_member8
Dear Samsung Member,
We regret to hear about your experience with our product.
●To fix battery drain issue please use the link to perform some easy troubleshooting steps: https://www.samsung.com/in/support/mobile-devices/how-can-i-optimise-and-extend-the-battery-life-on-
● Galaxy device heating issue: https://www.samsung.com/in/support/mobile-devices/why-the-device-heats-up-during-use/
You can reset your device by following the steps:
If the issue still occurs, please visit the service centre for a physical inspection of your device. You can locate your nearest service centre with this given link: https://www.samsung.com/in/support/service-center/
goodthings
goodthings
Your's most welcome to here.
