S22 ultra green line issue flikring problem after updating
(Topic created on: 11-04-2023 11:27 PM)
AMIN8108
7 Comments
AJAB_MORIA
Don't worry this is common. This happens not only with Samsung but also with users of other brands, which is gradually becoming better.
AMIN8108
Don't update
AMIN8108
You are lucky
which update you did?
AMIN8108
Oct 24 security pach update
muaad123
Same happened to me after sep update
cs_member10
Dear Samsung Member,
As per your query, we would request you to kindly perform the following steps to resolve your issue.
Adjust the brightness: Settings > Display > Adjust the brightness.
Check your device in safe mode: https://www.samsung.com/in/support/mobile-devices/safe-mode-on-samsung-phones/
Reset your device: https://www.samsung.com/in/support/mobile-devices/samsung-galaxy-mobile-how-to-perform-a-factory-res...
If the issue still persists kindly report the problems with a log file. To share a log file, click on the Samsung Members Application (Open Samsung Members Application > Support> Tap on error report > Type your query > Send).
