S22 plus display problem
(Topic created on: 10-05-2022 07:31 PM)
AsifSami
Glow around the punch hole . What is the fix of this ?
 really disappointing  - Samsung.
#displayissue
AsifSami
I am from Bangladesh
AjaySuresh
oh when did you buy this phone
AsifSami
4 months ago
AjaySuresh
do you still have this issue?
AsifSami
Slightly reduced after keeping the phone in the sunlight ( not recommended though ) as it is bad for battery . But yes i still have this issue .
cs_member8
Dear Samsung Member,
We acknowledge your query and apologize for the inconvenience caused to you and will surely assist you regarding the same. We request you to kindly visit the service center for a physical inspection of your device. You can locate your nearest service center with this given link: https://www.samsung.com/in/support/service-center/
god7slayer
Its not just the s22 ultra
I have the same issue with my note 20 ultra.
AsifSami
AsifSami
Should i go to warranty and display change ?
Or it could be more harmful ?
If i get a replacement unit , will it help the issue or the issue will also be there in new phone ?
god7slayer
Honestly if the phone is still under warranty I would suggest that you get the fixed.
